NEED HELP FINDING ZFS FILE SYSTEM FOR NETMASTER
Article ID: 102846
Updated On: 06-20-2018
CMDB for z/OS NetSpy Network Performance NetMaster Network Automation SOLVE NetMaster Network Management for SNA NetMaster Network Management for TCP/IP NetMaster File Transfer Management
Cust have inherited NetMaster installed on several systems.  They are in the proc-
ess of migrating it from r12.1 to r12.2.
On one particular system with r12.1 installed they cannot find the ZFS file system.
They have signed into VTAM interface and have run /PARMS but don't see what
the directory is supposed to be for WEBCENTER like it can be seen in r12.2.
OS: z/OS.
Process of migration from r12.1 to r12.2.
On r12.1 there are 2 PTFs used to implement MTC-NM (Mainframe Team Center-
Network Management): RO87296 and RO87683.
Once these 2 PTFs are applied to NetMaster r12.1 the parm zFS Mount Point is
shown on /PARMS group WEBCENTER.
