Issue with Primary Roles and making them not open for Time Entry
Article ID: 102831
Clarity PPM On Premise
We have some roles who show open for time entry and timesheets could then be created for these roles.
Is there a way to remove the value as this field is not editable for roles?
Steps to Reproduce:
1. Resource Object Attributes set attributes as follows: - Open for Time Entry - check the default boolean - Track Mode = PPM 2. The create a new Labor Role
3. Add the Open for Time Entry and Track Mode attributes to the resource list page.
Expected Result: Role is not Open for Time Entry and Track Mode = None. Note these fields cannot be edited for Roles.
Actual Result: Open for Time Entry = Yes and Track Mode = PPM
On the Resource Object, if the default value on the attribute 'Open for Time Entry' is checked (= yes), when a role is created they will inherit the 'yes' value for Open for Time Entry.
Reported as DE39199.
This affects 15.3 and prior
This issue is fixed in Clarity 15.4 and higher.
For a workaround on prior versions: Please contact Broadcom Clarity PPM Support for assistance
