Issue: When doing an initial load of the Automic database object into an Oracle database, the AutomicDBLOAD utility encountered error.
(When executing command "ucybdbld -B -X/opt/Automic/Utilities/db/general/9.00A/UC_UPD.TXT")
Error message:
20180612/140749.249 - U0029108 UCUDB: SQL_ERROR Database handles DB-HENV: a3ebc0 DB-HDBC: 0
20180612/140749.249 - U0003591 UCUDB - DB error info: OPC: 'OCIStmtExecute' Return code: 'ERROR'
20180612/140749.249 - U0003592 UCUDB - Status: '' Native error: '12899' Msg: 'ORA-12899: value too large for column "UC4"."DIVDB"."DIVDB_STRING" (actual: 384, maximum: 255)'
20180612/140749.249 - U0003590 UCUDB - DB error: 'OCIStmtExecute', 'ERROR ', '', 'ORA-12899: value too large for column "UC4"."DIVDB"."DIVDB_STRING" (actual: 384, maximum: 255)'
20180612/140749.249 - U0003531 UCUDB: Error while checking data source (e.g. code conversion or driver problem, see log file).
20180612/140749.249 - U0003594 UCUDB Ret: '3590' opcode: 'OPEN' SQL Stmnt: ''
20180612/140749.249 - U0038091 Change application directory to '../db/'.
20180612/140749.249 - U0003590 UCUDB - DB error: 'OCIStmtExecute', 'ERROR ', '', 'ORA-12899: value too large for column "UC4"."DIVDB"."DIVDB_STRING" (actual: 384, maximum: 255)' Application return code = 1
