Using SSL and Enterprise Dashboard will Not Start with $ in Password
Article ID: 101963
CA Application TestService VirtualizationCA Continuous Application Insight (PathFinder)CA Service Virtualization (DevTest / LISA / VSE / Application Test)
Getting this error when starting the Enterprise Dashboard using SSL:
Application startup failed org.grails.core.exceptions.GrailsConfigurationException: Error loading application.groovy due to [java.util.UnknownFormatConversionException]: Conversion = '$'
A bug with a Grails class file in the owner-1.0.6.jar in DEVTEST_HOME\lib\dradis folder.
Report in DevTest 10.1.0, but could be in others.
We have a fix for this issue.
Open a new support case and refer to defect DE364112.
