How to create a CA PDSMAN rule using protection against the Delete member and using the multi member Version?
Article ID: 10103
Updated On: 02-14-2018
PDSMAN
CA PDSMAN rule protecting Delete member and using the multi Version member.
MVS Z/OS
You need to build two rules for the concerned data set , see the following sample :
* Prevent member Delete
$UPDATE LIB=my.data.set
        PSR=Y
        MODE=P
        TYPE=DELETE
* Enable member Versions and Space Reuse
        VERSIONS=99
        PSR=Y
Update your PDSMINIT initialization file within the new rule,
then use the following command to refresh your new rule dynamically:
 F PDSMAN,NEWRULES
