Problems restoring the netqosportal and em databases
Article ID: 100227
CA Infrastructure Management CA Performance Management - Usage and Administration
When I try to restore the netqosportal database on a CAPC console, I get the following error:
[root@<hostName>]# mysql netqosportal -e 'source /tmp/netqosportal.sql'
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
CA Performance Management 3.5
A password was added for the root MySQL user in 3.5
On CA Performance Management use the password for the root mysqluser and commands as outlined in the documentation.
CA Performance Mangement 3.5 documentation:
Backup:
https://techdocs.broadcom.com/content/broadcom/techdocs/us/en/ca-enterprise-software/it-operations-management/performance-management/3-5/administrating/performance-center-administration/back-up-performance-center.html
Restore:
https://techdocs.broadcom.com/content/broadcom/techdocs/us/en/ca-enterprise-software/it-operations-management/performance-management/3-5/administrating/performance-center-administration/restore-performance-center.html
